potential problems with my final build
16 Jan 2009
Hi, ive decided on the following build and im ordering the parts very soon, but before i commit to ordering, can you see any problems that i might run into while building this pc? ie - will it fit in the case? do all the components work with eachother? will it overheat?
Also, is there anything i need to know about setting up the bios or any kind of walkthough i need to follow to set this pc up? or is it literally just plug and play?
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939) // £91.99
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail // £151.79
Gigabyte GA-EP43-DS3 Intel P43 (Socket 775) PCI-Express DDR2 Motherboard // £86.24
XFX ATI Radeon HD 4830 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail // £77.04
OCZ StealthXStream 500w Silent ATX2 Power Supply // £51.74
Antec 300 Three Hundred Ultimate Gaming Case - Black (No PSU) // £50.59
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) // £40.24
Corsair XMS2 4GB DDR2 PC2-6400C5 TwinX (2x2GB) // £33.98
Arctic Cooling Alpine 7 Pro CPU Cooler (Socket LGA775) // £9.19
LG GH22NS40 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM // £18.39
Sub Total : £531.46
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.75
VAT is being charged at 15% VAT : £81.78
Total : £626.99
Cheers
what is the system going to be used for? whats your budget? the components should all work together fine and i doubt it will overheat
basically its going to be used for a bit of low level gaming, ie - lotr bfme 2, civilization series, wow. nothing major. And programs like, maya, visual studio 2008+, expression blend, flash, photoshop etc. Is anything ive got in there overkill? Plus my budget is really about £600
Im more concerned about building the pc than its components
ditch the Gigabyte DS3 mobo and get an Asus P5QL Pro one instead, again saving an extra few ££'s.
Everyone has concerns about building, even the most hardened builders are always anticipant at the first power button press. Always read the mobo manual when installing, don't rush and everything will be fine. I usually put the cpu and memory into the mobo before putting it into the case. Figure where you are going to route the cables, always try to keep it neat and tidy(better airflow).
