Before I pull it out and try and connect it to something else, is it normal for a powercut (in this case, my Dad fitting a light even with the supply cut off tripped the RCD) to kill an SSD? It's a 128GB M4. Rather irritating, as I'm sure you can imagine!
Last backup should have been 2am today so no data lost, but at the moment it looks like I'm going to have to put a temp old drive in
What's the warranty situation in this instance - it was only a power cut, surely it should be able to cope with that?!
,it will usually corrupt the cmos if theres a power cut or a hard bsod
