I can't afford anymore delays the new PSU is coming tomorrow so hopefully I don't have anymore issues. I appreciate all of your help, I was surprised how many of you offered feedback and suggestions it made things alittle less stressful, though in hindsight I probably should have just gone with the PSU you guys recommended and payed the difference but Im so strap for cash already and the seagate seemed like a decent upgrade so I agreed. I can't really fault them on there support, they were fast to respond and helpful it's just been a bad experience of delays getting the system, chasing for my free offers, then the PSU dieing after literally a few days use. If I have any problems with the new PSU I will report back. The case is kolink and Im very happy with it so far lets hope it doesn't spontaneously combut too. Thanks
Got to ask the obvious.Thanks for the info it's always good to use forums to get some advice or second opinion, my nightmare however continues, I just received the new PSU hooked it up hit the power switch and besides a small clicking noise nothing happened. Looks like im back were I started.....
Lol, panic over!
That click propably came from PSU shutting down when protections got triggered.Thanks for the info it's always good to use forums to get some advice or second opinion, my nightmare however continues, I just received the new PSU hooked it up hit the power switch and besides a small clicking noise nothing happened. Looks like im back were I started.....
Edit: Im sorry guys false alarm my dad was trying to be helpful and he fitted the new PSU but he plugged in the PCIE into the CPU. I should have checked he had done it correctly.... System is up and running nothing has exploded yet. Sorry for the mix up Im just glad im back now typing on a usable desktop...
Also when doing something inside case/adding parts never close case untill you've tested that everything works.Slightly embarrassing :')
Did you try turning off hdr to see if that is the problem ?
I would start a new thread in the monitor section as well.
after reading this thread im surprised overclockers are even selling the Kolink psu's and even worse, using them in their pre built systems. ive read a few problems on here to do with kolink psu's and from what ive seen its best to avoid them and always buy a decent quality onemake sure the gfx card is is using 2 cables from the psu not just 1 cable split in to both slots on the card!
