its a complete head **** the first time around, once you get your head around base clock being king and not multipliers its easy enough.
Agreed.
Ok thats good, even if limited if it does have an unlocked Multiplier then i'm happy with that.
One thing i hated about the X58 was messing on with the FSB and memory multipliers, its was like going back to an early Athlon.
They are cheaper than the 3770K so its a good option to keep my eye out for, thanks
I will keep this quote for future instructions.
Sorry for off topic but, upping the BCLK is safe now? Last I heard it confuzzles (2600k.z68 era) the other components in your system..
Overclocking
The R9 290 comes with reference clock of 947Mhz Core and 1250Mhz Memory
The PCS+ R9 290 is 1040 / 1350 out of the box, on stock volts I managed to get it to 1125 / 1450, giving it a total 19% overclock on the core and 16% on the Memory, stable with no artefacts.
[/SIZE]
I make it 8% overclock on the core and not 19%, 1237Mhz would be a 19% overclock.
Very interested In getting this card any ideas what the warranty process is via ocuk?
also i have a good quality 750w PSU i know this is required or greater rest of the spec below would i need to contemplate an upgrade also not planning any kind of overclocking on the card
4790k ghz no overclock
8gb ddr3 ram 1600mhz
Hey humbug; nice review.......but can I ask what the length of the card is? that's the one I'm seriously considering but need to make sure it will fit LOL
29.5cm ish
I also really like the glue they added to reduce/stop coil whine.
i find the auto fan profile to be annoying with the hot weather it does get rather loud when its not needed on auto it sits at 60c but the fans go up to 60-70%
if i obviously stick the fan profile lets say 50c it never goes about 60 and its vastly quieter
my question is would i have to keep going into settings and keep changing the profile speed every time i want to game or is there a quicker way?
edit:just realised i could just set it to an appropriate speed and just make sure temps stay below 75c ? keeping fan speed consistant wont reduce life would it?
It's little things like this that really make a different to the end customer. More companies should take a leaf out of their book and follow suit imo.
The RMA for Power colour is stunning, I had to return 3 R9 290s and the replacement was sent out the same day they received it.
