Powerful Cooling
Well im going to return the H100i which cost me £84 so i had that much to play with. Decided to go with this in the end because ive owned one before so i know what its like and how much cooler is it than the H100i. Its a bit of an eye sore, but what can you do? At least the colour of it will match my reference 290's. :D I abandoned my blue theme a while ago.
I have that very cooler, same colour too....and its a bit on the pink side
although i should have gone for the black one again
Pink? Oh crap. Hopefully it blends with Radeon Red.
Was just dispatched from ocuk as well. Not sure if it will arrive tuesday or wednesday tbh.
Well it's not too pink....but a tad pink-ish lol
maybe the black would be a better option ?
Too late now, its en route. Will inspect it when it arrives. Unless its really pink, ill likely keep it as it looks like it will blend nicely with my 290's. Add a few red cables and bobs your uncle.
When I pulled mine out...I thought....It's pink lol
I hope thats not a euphemism.
Only one way to beat the Heat of Hades is Custom H2o full.:)
Only guaranteed way, break out the razor blade, hairdryer, vice, or any other delidding method. Custom water alone on hw makes hardly any difference over top end air cooling.:)
What CPU you running at 5Ghz? What were the temps before and after with the H100i & Phanteks.
2700k @1.424v
Can't remember how much cooler the Phanteks was, but it was cooler and quieter. H100i won hands down on looks though. When i was playing Crysis 3 earlier one of the cores got up to 77c during the level with the moving grass. It was at this point i knew i needed something extra.
Yep, if i leave my cpu fans on auto, (k2 with dual 2350 rpm corsair sp's). Temps will get to 77c, fans set to full speed knocks it down 10c.
