Hi there
OcUK has secured 100+ of BenQ's latest and amazing XL2720T 120Hz 27" LED Gaming monitor, were doing a reduced special price for pre-orders only and stock is due end of this month.
So save some money and get your pre-order in now:-
Benq XL2720T 27" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red @ £379.99 inc VAT
The XL2720T demonstrates BenQ's true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming. Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2720T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you're able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3. conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by the legendary Counter-Strike players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
Meet your secret winning strategy. The FPS Mode was co-developed with gaming legends to let you tap into the fundamental insights of pro gamers and view the game how a gaming legend would see it. This out-of-the-box preset automatically adjusts your monitor calibrations to provide you with optimal brightness, contrast, sharpness and color tint. Being able to spot your enemies and track their move carefully in every situation put you at an advantage over your opponents.There are two variations to this special mode: the FPS1 mode is designed to configure and optimize the display for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source as recommended by BenQ. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:10), 21.5"W (16:9), 22"W (16:10), 23"W (16:9), 23.6"W (16:10), 24"W (16:9) to 27"W(16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
With a refresh rate of 120Hz, there's never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2720T gives you on-screen action and captivating realism. Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2720T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy. BenQ professional gaming monitors are not only the official global Tournament monitor of top notch league and tournaments, but also unrivaled victor of world renowned design awards. In addition, BenQ professional gaming monitors are used by prominent gamers to perfect their gameplay.
Specification:-
- Back Light Unit: LED
- LCD Size: 27"W 120HZ
- Aspect Ratio: 16:9
- Resolution (max.): 1920×1080
- Pixel Pitch (mm): 0.311
- Brightness (typ.): 300 cd/?
- Contrast (typ.): 1000:1
- DCR (typ.) (Dynamic Contrast Ratio): 12M:1
- Panel Type: TN
- Viewing Angle: (L/R;U/D) (CR>=10): 170 / 160
- Response Time (Tr+Tf) typ: 5ms, 1ms (GtG)
- Display Colors: 16.7 million
- Color Gamut: 72%
- Input Connector: D-sub/DVI-DL/HDMI/DP
- USB Hub: Donwstream x 3, Upstream x 1
- VESA Wall Mounting: 100X100 mm
- Swivel (left/right): 45/45
- Tilt (down/up): -5/20
- High Adjustment (mm): 140 mm
- K-Locker: Yes
- CTN Dimensions (HxWxD mm): 486 X 711 X 245
- Dimensions (HxWxD mm): 548 X 642 X 273
- Dimensions with Wall Mount (HxWxD mm): 485 X 642 X 269
- Net Weight (kg): 7.5
- Gross Weight (kg): 10.2
- Warranty: 2yr
Was [£419.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Specification:-
- Panel Type: TN
- Color Gamut: 72%
- K-Locker: Yes
- Warranty: 2yr
ORDER NOW
