Hi All,
Looking to switch back to PC from Mac. I am looking for a machine I dont have to build myself (yes I know its pretty easy I have done that in the past but these days I value my time more than saving a few quid).
I have a hard budget of £2500. I am looking to go fairly high end on everything except the graphics card as I will likely switch in a 3080ti or equivalent when they are released.
This will mainly be a gaming machine as I have a work laptop however I do occasionally use it for work when the laptop does not have enough horsepower. I game at 5120x1440 @ 75Hz (32:9) and later I am looking to buy the 48" LG OLED TV so hoping to get close to 4K @ 120Hz with just a graphics card upgrade.
Some other considerations I dont want a mechanical hard drive so a large SSD is a must.
I dont like RGB so a case with no window and prioritises airflow and acoustics over bling is ideal. (Looking at Define R6 or similar)
I will be looking at building a NAS further down the line so faster than gigabit ethernet is a plus ideally with dual ports.
Can you recommend either a full system or a list of parts that I can ask someone to build for £2500?
expect 2080ti to hit over £1600 easily enough . might want to hold off the trigger till after March, but normally its **80 and 70 with the release followed by 60 and then Ti - normally a year in
