If you're not clocking the Wraith Spire is fine. You can add a 120mm cooler for approx £20 if noise is factor but the reality is, if the primary use is gaming, the GPU fan will drown out all other noise when it's taxed.I presume the cooler that comes with the 2600x is sufficient and I don’t need to buy another? Ta
I am sure you'll be interested to hear, that competition at that end of the market is going to get weirder too, since from the info I have been given the 2700X is going to be <£199, the 2700 <£159 and the 2600 <£109, with the 2600x <£129, should see the prices from 1st July or maybe a day or two before apparently.
It will have its uses in some games and increasingly so in the next few years with bigger games - but the 2600X will still be very capable until ZEN 2 upgrade.Thanks for that. Might be worth waiting to see what happens. Is it worth the extra for the 2700x over the 2600x for my purposes?
Sounds good to me, I’ll divert the extra cash towards the monitor!
grey keys can be had for a fiver.Also where best to buy Win10?
looks good.MSI B450 Gaming Pro Carbon
Ryzen 2600X
HyperX Predator 16GB DDR4
Sapphire Radeon Vega 56 Pulse
Bitfenix Whisper 650W
WD Blue 1TB SSD
unfortunately gone are the days of minimalistic cases.And can anyone recommend a case that is fairly minimalist and preferably not have a window on the side or loads of bright lights?
haha indeed. but their RMA services do need a kick up the backside though...just stand firm on your demands and they'll cave in.For example, you can pick up this AOC for ~£200. It's an IPS 1440p panel and 32" (nuts value) and forum member @tamzzy - whose very savvy with component investment (i.e. won't spend if can be avoided) - recommends them so much he bought two of them. AOC have a decent warranty and great pixel policy too.
to be honest. the AOC Q3279VWFD8 is the best bang/buck for a larger sized monitor.Also what’s the scoop with curved vs flat monitors - is one type better than the other for gaming or largely irrelevant? I’m pushing the boat out on monitor to up to £300 and don’t know whether to go 24 or 27 and flat or curved, there’s a few options in this price range and bamboozled by choice!
it isn't. i own two! and use it on a desk.Thanks! 32 is way too big for how close I’m gonna be to the screen I think
IPS: better colours, better viewing angles, slower (compared to TN) pixel response - but not too terrible to cause ghosting, unlike VA panels.Or should I be looking at IPS instead of TN?
4k is basically unusable at 27 inch.3480x2160
i had a 28" 4k monitor and had to use scaling...which made having the increased pixel density pointless.
also you'd need a decent graphics card to drive that resolution unless you turn the resolution down...which then makes having a 4k monitor...you guessed it...pointless. lol
either get a 1080p screen or a 1440p screen.
4k isn't worth it except for a few niche uses...and even then, the minimum acceptable screen size is usually >40"
