yes. cable from the psuAnd now I’ve read this I’m assuming that it plugs into one of the sockets on the sata cable that I connected to the ssd?
3333 is the rated speed. You will need to go into bios and enable docp to get it to run at 3333 (default is 2400). Well worth it though. You get a nice 5-10% boost in performance just by going 2400-3333 MHz
Nice one cheers! Will do that! All other hints and tips like this most welcome![]()
or use the ez mode screen and do thatOr click xmp button at top left of bios screen and select 3333 profile.
its correct. windows makes all the extra partitions. just install windows onto the biggest partition.And now when going back into windows setup I have this where I only had one entry for ‘drive 0 unallocated space’ before
might be the ram speed too fast for the cpu...not all cpu can run 3333 mhz...try the profile with 3200 mhz instead.Ok somethings up, during windows install the computer restarts, goes to black screen and a red cpu light on the mobo. There’s a consistent ticking noise after this happens (cpu fan and case fans are still running).
If I power off and restart it boots again fine to the windows installer but then happens again during windows install (not always during the same point)
yeah, sounds like the cpu didn't like the ram speed too much. 3333 is normally pushing it...need to have a golden chip to run that fast.Have reset the bios to default and touch wood it seems to be installing ok!
what ram speed?Spoke too soon, same thing again, cpu red light and ticking![]()
what ram speed?
how did you connect the power connectors on to the GPU? take a picDefault 2400
