Printer problem
24 Oct 2005
North East
I have a epson stylus c42 ux. Got it for my birthday years ago.
The last year the black hasnt printed very good. I.e no matter how many nozzle cleans i do the black print test pattern has white lines in and the black test is fuzzy.
What can i do to get it like the colours which print ok?
It may have dried out of it isn't getting regular use. If you're sure it isn't completely full, i'd replace it.
You could try and take it out and physically clean the open end with a bit of paper or kitchen roll to see if that helps. It may have dried up though.
Its not the cartridge as its happened with 2 diff carts. Its the nozzle for the black i think theres something thats causing quality decline. Not sure how to fix it.
