Problem installing W7 on M4 SDD
13 Jun 2007
South East Uk
I have a M4 128GB SSD. I have been running W7 on it fine.
I am trying to do a clean install but when I get to the install part I get the error...
"Windows cannot be installed. The selected drive is of the GPT partition style"
The box displays 3 partitions.
Disk 0 Partition 1 100mb
Disk 0 Partition 1 128mb
Disk 0 Partition 1 119GB
Any advice appreciated.
the partition or the whole drive?you might need to format the whole drive and redo your partitions or format each partition again back up any data first
W7 install only allows me to format the individual partitions not the whole drive.
I have formatted each partition (except the 128mb partition which is reserved for windows and I cannot partitioned.
It will let you delete partitions though, just delete them all and start from scratch.
I'd recommend cleaning the drive off and letting windows recreate the partitions.
Try pressing Shift-F10 at the language screen. You should get a command prompt from which you can run diskpart and clean the SSD (ie remove all the partitions and boot sector etc). Then quit out, close the command prompt and install as per usual. Careful you don't nuke the wrong drive though!
