Ok I might order some of that but if I do it means im stuck with this stuff untill at least next month untill i can RMA it - will speak to a friend about it first to see what he thinks first
do the heatsinks on that memory stick out above the actuall ram stick itself or is it normal sized ?
its hard to tell from pics but looks the same size,if you measure the hight of your ram and maybe someone who's using teamgroup Vulcan can measure theres
Ok I will talk to my friend again he originally said to not bother my stuff is fine
(still might be)
but even he said So low profile 2x4 then 1866
was going to chat to him tonight but I think he may of gone to bed so will chat to him in morning before I ask if he can come over & pull pc parts out for RMA
still got no idea what problem is or if this will even solve it
anyone else care to chime in & offer some advice or opinions ?
Looking good so far after a admin from msi forums gave me the 1.4b2 bios to try watched a hour long video in 1080p full screen no bsods and played arkham origins for nearly a hour no bsods off to a good start but to early to say yet could still go wrong.... Only Hicup I had was a freeze of pc when I told it to shut down
Ive asked over the phone if it should work with my board and chip and they said it should do or be ok etc sounded like they knew what they was talking about
the height of the ram doesn't look bigger then standard ram and if it sticks out more it should not matter those 2 sticks will be equall to the the amount of ram I have at the moment just take up less slots
might have it tommorow or thursday
then I can at least eliminate the ram if problems still persist with this stuff
then will eventually look at PSU next if no luck then
