Problem with HD4870
* Power off the monitor
* Disconnect all cabling from the bottom and/or sides of the monitor (especially the power cord)
* Press and hold the monitor power button down for 5 seconds
* Reconnect only the monitor power cord and the #2 white DVI
* Power the monitor on
* The PC should already be on. The monitor should auto sense the #2 white DVI. If it does not, press the Input Select button and change to #2 DVI
Any difference?
As per some instructions from a Dell employee the above has just worked for me !!!!
