problems setting up a home network?
Man of Honour
11 Mar 2004
Im having great dificulties setting up a home network.
I have a linksys router, wich both computers are connected to.
Both can connect to the internet fine.
Both machines have static Ip addresses.
Machine 1 is connect by lan
Machine 2 by wirless
Machine 1 can see Machine 2s files as long as Machine 2s firewall is off.
Machine 2 can see machine 1 when machine 1 firewall is down, but cant see the files or anything else.
Ive tried setting up both firewalls to allow acces from the respective Ip addresses but it doesnt seem to work.
Any ideas, guides or help..
Is there a config file or something I can post to help?
Which firewall are you using and have you ran the Windows XP network setup on both (assuming they're both XP)
yep both xp, yep run the network setting on both,
Machine 1 is Zone alarm pro. Running XP prof
Machine 2 is Bullguard Running Xp Home (if that makes any diff)
make sure all pcs have, file & print sharing turned on, and all pcs are on the same workgroup
allso if any of them are using windows 2000, make sure the Guest is active via Administrative Tools> Computer Management> Local Users.. Users
yep both of those are ok.
nope both xp.
hmm u could manualy set the ip's for each pc and im sure that will work
here is a screeny of what to do
all u have to do is add the router ip to the boxs marked and change the X to any number from 2 to 255 for each pc
reboot both pcs and that should work
the only other thing it could be is a windows login thing? but im not sure
as all the setting you have done should work
what do you realy mean by .
do you mean another pcs shared folders?
humm I might unistall this bullguard and install zonealarm. Cos its working with the firewalls down (well at least on one cpomputer)
