Hi folkes,
Looking for a bit of help.
AMD phenom x4 @ 3Ghz
OCZ reaper DDR2 6gigz @ 800 5 5 5 18
latest bios version (however it hasnt made any difference throughout)
2 x HD5770 ATi
Problem is=
I have done a lot of testing recently using various programs that friends have told me to and it is proving the crossfire is working. HOWEVER, when i benchmark games such as flight simulator x and battlefield bad company 2 which i use regurarly i get around 120FPS with 1 graphics card running! (no crossfire enabled)
Soon as i turn crossfire mode on i do the same (exactly) tests again and typically the system seems slightly slower also the main part is the FPS has now dropped to half usually. APPROX 60-70 FPS.
Now i havent messed around with anything at all iv changed all the bridges that doesnt make a difference latest drivers for EVERYTHING which hasnt changed anything. Changed all the settings throughout ATi and others hasnt changed anything really. Believed to have the correct BIOS settings that doesnt change anything either.
should there be a performance decrease or should i see a GAIN in FPS?
At the moment im just playing single GPU with 1 graphics card running since im getting higher frames on the 1...
Also did this today to check each card. i have taken both cards out checked them over. Replaced 1 of the cards back in and ran the comp tested again and nice an high frames. Taken that card out replaced it with the other 1 done the same and exactly the same outcome, nice high frames.
putting both cards in once more running same test after configuring it to run in xfire mode i get poor frames =( ? ? ? ? ? what on earth is happening any ideas?
power supply? its 850watt supply.
Any ideas on how to get both cards working perfectly?
Regards,
Martin.
2 x HD5770 ATi
Problem is=
Regards,
Martin.
