Just had a quick play with overclock settings.
New profile from OC has definently solved the warm boot / restarts.
However the cold boots still have problems (first boot of the day is always fine though)
I tired downing the multiplier so the chip was only overclocked to 3ghz, but this still caused an issue (left the rest of the settings as they were in OC profile)
I then loaded the standard settings and did a basic overclock to 3.5ghz (no voltage / ram changes). This loaded fine everytime, and the system seemed stable. Also on a normal bootup, i only got 1 test cycle.
By test cycles i mean this:
When the computer starts the Graphics card will fire up to full speed, then slow down (This is 1 cycle, the diag display will show C1, then blank, then come back)
Generally with the overclockers profile i get 3 test cycles, then the system will start.
On cold boot after the system being on, the computer will come on, then go off very quickly.
I then get it back and get 3-4 test cycles, then the power goes off again.
Then power back, 1 test cycle, and systems starts with O.C error.
Any ideas? Maybe the voltages need playing with. I tried setting some of the voltages from AUTO, to their actual running settings, but couldn't actually get it to boot with that profile.
