Problems with my drives
24 Oct 2005
North East
I have a 30gb Maxtor drive and in HDTech i do quick test and i get this
This is for the 200gb maxtor diamond max 10 drive.
Also when watching movies sometimes they stop and i hear hdd spinning hard. What can cure this? I think its just the 200gb drive doing this as before i got this drive movies were fine on 30gb drive.
Please help cos im sick of the slowness.
Also dont say its cos there maxtor drives. They were fine and 30gb has been good for past 4-5 years now.
No replies saying (meh maxtor_ or the such.
The HDtach is slower than expected but do not point unduly to any specific problems with the drive itself (DM10). As wizardmaxx states, it could be spyware, malware or even something as simple as the Windows Indexing service causing HD requests and slowing down the HDU.
Place the Maxtors in the bucket, and weeeee! :D
Seriously though have you done a full surface scan? What do you mean "it spins hard" It stays at the same rotation speed, when a drive is faulty it doesn't change rpm (unless motor/bearings are damaged) Is it clunking then pausing when reading the same bit of data? You should spot unusual HD noises, if it has bad sectors. If the board is faulty that's harder to diagnose.
Aaah, a good old fashioned trebuchet! :D.
Have you checked SMART data for the drive at all - something like Speedfan has this ability.
Here are speedfan smart full diagnostic reports.
30gb
200gb
Also theres some fragmentation on drives but windows defrag tool says dont need to be defraged right now. Will defrag when i can find more space tho.
So erm any suggestions why and how to fix these issues? I did adaware and got id of some stuff but this was a few days ago and as you saw in first screenies it didnt help.
