hey
ive just after putting together my new pc and when i boot up i get this msg;
'Reboot and Select a proper Boot device or Insert Boot Media in selected Boot device and press a key'
i tried resetting and going into the BIOS of my Asus P6T SE mobo and changed the booting sequence so that my DVD ROM is 1st.
i save + exit, reboot (with a copy of Windows XP in the drive) but yet again i keep getting the same message.
i happened to notice that during the booting sequence, the screen will pop up with some text at the top and then 'Detecting Drives; Done; Drive not found' before clearing within seconds and giving the message above. in the BIOS however, it is picking up the make and model of my HD and DVD ROM.
does anyone know how i resolve my problem so i can boot from the DVD ROM and install an OS?
cheers!
EDIT - i've tried all the SATA cables and checked the cd on another computer and they are not the problem
EDIT2 - the BIOS is noticing both my Samsung HD and Sony Optical DVDRW both with model numbers + i checked the SATA controller and it is already set to IDE.
cheers!
