PROJECT:1st WC build
Where did you mount the 360 rad? At the top? If so, could I still get a DVD drive and dual bay reservoir in there if so?
3 bays left if you mount rad like this but 1 of those is the hdd hot swap bay. Spose you could mod it to accomadate a dvd drive. I personally dont use a drive 99% of the time so i left it out. Ssd is mounted using velcro on the back side of the case.
Here's a couple of pics of my Switch 810 build with a 420mm Radiator in the roof.
Holes slotted for rad/fan mounting
140mm fans fitted
In the roof you can fit a 120,140,240,280,360,420 (upto 80mm thick, 55mm if going push pull)
I have my mechanical hdd in the hot swap bay(bottom one) and my ssd is velcro'd to the back side of the case.
Cheers. I had finished the build but I decided to replace the HD7850 with 2 watercooled 7970 Lightnings so its back in pieces lol.
i'm after another ltg but its gonna have to wait until after xmas, really gutted i missed pgi's deal, but i'm sure more will come up.
gonna get another rad in too inbetween cpu and gfx, and then re route the long tube from top rad to the aquaero w/b in the roof, just so motherboard is more visable and looks tidier
get some pics up when your done and give me a shout :)
If you don't fancy voiding your psu warranty grab some cheap non braided extensions and braid them :)
Love that memory on the mpower.
Project shift
going x79, just ordered a rampage extreme, 3820(sidegrade for now, gonna see what ib-e brings) and 16gb Ripjaws Z 2133MHz cas9, and a couple of red fans and red coolant, roll on tomorrow :D
