Finaly,
I'm up to the most enjoyable part of the project.
The job at hand now is the side panel.
Ht pannel was previously primed, then wet block sanded to a smooooth finish before getting plenty of very very thin coats of black base coat. left to harden over night, i returned with a scotch pad to smooth he paint down and give it more 'tooth' for the art work to stick to,
once this was done, i wiped the dust of my old overhead projector and set about transfering the design onto the panel.
Now, in some peoples opinion using an OHP is cheating. But really, it isjust time saving, and the amount of time it does save is well worth it. It means i can compose the panel correctly, first time. and not have to re-draw anything.
The down side is that the amount of information you can transfer is very limited. You will see from the next pic that i have only drawn the most basic of lines - the rest i fill in with the airbrush by eye.
Its always a pain too as the design constantly quivers and moves around as the OHP gently humms away. just the nature of the beast though.
NO masking?
I tend to do all my art work as free hand as possible. Masking can leave harsh edges which are hard to soften. And i find i can get edges as hard as i need - freehand. - It is a bit of a black art, but worth the effort.
So on with the painting its self.
I can see how most people would think this face is almost finished, but it is far from it. This picture demonstrates only 2 coulours form the airbrush - pure black and light grey. For work of this nature i normally only use a hand full of shades and let the airbrush blend them together.
I spray at pressures that would make most airbrush artist wince - its just the way i prefer, although it does leave me with faint overspray, so i find my self re-filling black areas in again toward the end.
heres what i have so far... cant wait to get it all done now!
Whats all that mess on the side?
a lot of my projects that you see will have random squiggles on the sides, this is simply the area i use to test a line on the airbrush, or get rid of paint gathered on the needle... it gets covered up in the end.
stay tuned guys, were onto the best parts now!!
Rick B
