Wow, just wow!
Absolutely stunning, after looking through this thread i had to spend the next 30 mins looking at all your other threads and projects!
100% talent, amazing stuff, glad to see your using it and putting it to good use
Is this what you do for a job?
Gl with completing the project, cant wait for the updater!
I do this on the side, as i already have a full time job. So when i have a project on the go, i pretty much paint from 6pm onwards.
Glad your enjoying it!
First update of the night, after this I'm going back to work and do some more.
BEFORE YOU LOOK! ! !
There are some parts of these images which look like mistakes, and look completely wrong. Don't worry, they are not wrong as such, just not finished!
I am still onto the first 50/50 grey layer of paint, and because of this, some parts ( eye socket) look terrible at the moment, I can see how to some it looks kinda finished, but it is no where near!
#1
Starting to define the eye socket a little more with black, this are is going to receive a lot of attention later on, so looks bad at the moment.
I have also started the refine the hairline / face a little too
#2 Starting to fill some areas of the glove hands, these will receive more attention later too, make them look really old and work, with the stitching showing - this if you like is just the under painting of it all.
#3
more work on the glove, and starting to suggest some hair
#4
A little work on the lace parts of the dress, more work ont he glove and more added hair. Also i have starting to suggest where the folds in the dress will be.
Lastly i can share a little bit of technique, This is the shade of grey that i a using, its quite dark - although it shows up almost white on the black panel. from this i will go 75/25 white/black, then 100% white
and also 25/75 white/black, then 100% black
Heres is the same colour on a white support.
