The GPU block that I had was from Alphacool for the RX480, this came in black with blue font, however I wanted to paint the block to either white or silver. With help and advice from a good friend Admodz. I set to work on stripping the block down. I started by taking the actual water block off the cover as this cant be touched. Once I did this I was left with just the backplate and the heatsink top itself.
The method to stripping these is actually quite a surprising one and left me a bit sceptical as to the effectiveness of it, however I trusted Adam's advice and set to work. I placed the blocks into separate containers that had water in them, and added Mr. Muscle drain cleaner pellets. I left them for a few hours and before I knew it, the solution had completely stripped the paintwork from the blocks!
I was so impressed with the results that I have actually decided to keep them the way they are as it ties in well with the chrome and silver accents throughout the build theme.
