Project Android
messiah khan said:
No more work been done it im afraid. Theres not much I can do this weekend, as I need parts and materials to any more, and im skint now until payday. :(
Messiah Khan online trust fund? :D
I got paid today! :D That means i'll be ordering more parts and materials later today, so I can carry on with the build.
@VeNT.. Yeah, im tempted as well, but I have no idea how to do it. I could probably do the whole motor part, but how do I build a controller, get it linked up to the pc and then get software to run it?
@FENIXfatboy.. Cheers :D
@Immortal.. Cheers :D
@jcs1987.. Cheers, and yes it potentially might be for sale after ive lived with it for a while. I mean I will have to make space for the next mod anyway won't I. ;)
there was a lego kit out that had a webcam attached, simple software that had motion detection, ie if things happen in left side, move left etc
someone made a SG out of one.
btw, is that pic in the op from a Bjork music vid?
what about those *Spy Cam* Wannabe's.
I have a wireless cam that can be powerd by a 9v battery or mains (rig them to PSU) they have a mic in there and an Infa Red motion sensor with a 90degree motor with it! i can mount mine in a ping pong ball so all would be sweet! i got mine off E**Y @ £21 brand new!!!!
I Might have to have a look at those.
Yup. Its from the 'all is full of love' video by chris cunningham.
love that bit, goes a bit strange at the end tho.
wasn't it the worlds first lesbian robot thing
Cheers. :) More parts arrived today, so once this hangover wears off a bit, i'll get some more work done. The box that turned up today contained 2xRJ45 inline crossovers, 2x 0.5m UTP cables and a 4 port usb hub. These will allow me to make 2 network ports in the spine, which are the final spine sockets to be made. Once thats done, I can start to smooth the inside using car body filler.
YAY!!!! Updates!! :D :D :D
ChoÞÞer said:
WOOOOOOOO :D
what if you got the head movin? insted of webcams? ;) :rolleyes:
Fancy working out the mechanics and electronics i'd need for that? :p
Im not likely to post an update tonight, as I havent done much work that is visible and some epoxy glue is setting so I don't want to move the thing at all. Ive basically modified the inline couplers, so that they are at 90degrees instead, which will give me the clearance behind the motherboard. Ive also cut the holes in the spine, and currently waiting for the glue to dry. Ive also filed the chesplate down a tiny bit to make it fit snugger over the rib bolts.
who said you need mechanics and electronics??
hire a kid, and put stick behide its head and get the kid to move it everytime you move
:D PRICE LESS :D
Not that much to show this time, but here you go anyway;
First I filed down the chest plate a bit, so that it slots over the bolts holding the ribs down. It all fits nice and snugly now.
The other job I have done , is to make the network ports in the spine. As you can see from the following pic, I have snapped 2 inline networkcouplers in half and turned them 90 degrees which was much easier to do than I expexcted;
The back of the body has holes cut in it, in the shape of the RJ45 plug;
And finally a pic of all the sockets in the spine. The 2 network ones were the last I needed to do, which means I can now start work on smoothing out the inside using car body filler.
