Project Android
messiah khan said:
Lol, thanks for the suggestion Yewen, but I think im going to stick with a standard momentary switch, which will be placed in the head.
Not the nipple or the *ahem* then....!!
jellybeard999 said:
the nips should be rheobuses... for tweaking :D
Such a good idea, I may have to concur.
Would look a bit weird, but a touch sensitive nipple for the power switch, or something along those lines would be very very cool.
Nobody else would do it, guarantee you that.
Lets keep it remotely on topic. ;)
(I don't beleive I have just said that. :()
When is the next time you will put any time into it?
Also, are you planning on a full project log for it as I would like to be able to add it to the sticky?
Yeah sorry Yewn but someone had to say it. Congrats by way on the upgrade here etc!!! This has to have a full log for sure
Im still working on it most days, but im waiting until ive made some decent visible progress until I add more pics etc(Ath the moment im just doing monotonous structural work). So, yes I will be doing a full progress log. I'll just post my progress in this thread for the moment, but I can neaten it up etc once im finished, so that you can put it in the sticky(Thanks for the offer, that would be ace :) ).
Edit; And no guys, im sorry, but her nipples are not going to be switches, LEDs, Cold cathodes, fans or anything else :p
Dam.... I was hoping they would light up when you switch her on :(
Love the idea though!
Are the mass of OcUK forum users under the age of 13 or are they all hitting the middle-ages?
Leave that model's chest alone! :D
I have now reattatched the lower torso to the upper torso. The initial plan was to use alluminium strips and epoxy glue. But after the first attempt wit the glue collapsed as soon as I removed the clamps, I deceided I needed something stronger, so I went out and bought a riveter. I love rivets! The structure is now rock solid and was really easy to do.
The next step was making some small 'platforms' to mount the motherboard tray on. For this I used epoxy putty. This stuff is great, its easy to mix and takes only 10 minutes to set rock solid. I needed these platforms, as nothing in this 'case' is at rightangles or flat.
Once the motherboard platforms were set, I cut the motherboard tray out of a sheet of steel. I did consider using a sheet of alluminium, but this turned out to be too flexible. Ive now drilled holes in the corners of the mobo tray to mount it to the case. I still have to drill holes to fit the standoffs into. I can't get hold of the correct tap for the thread used, so im probably going to have to use a nut on the other side to hold the standoffs instead. Im also going to rivet some aluminium angle section on the back of the mobo tray to give it some more rigidity.
And here's a final picture for now, showing what the thing looks like with the chest plate in place. The chest plate is going to be hinged from the top, with a magnetic clasp holding it shut at the bottom.
