Project Android
I like the idea of the chest hinging upwards but how about using a piston thing from a car boot to lift it up, and use a one of those door latches you push to release then push again and it latches on. That way you can push her chest and it will lift up of it's own. ;)
You could even rig up a fridge like switch to turn on a light in the chest cavity when you open it up.
Thanks for the comments guys. :)
I had actually considered the piston idea. I have no idea where to get a suitable piston or how to mount it though. I like the 'fridge light' idea, thanks for that. I might end up using that.
Would a basic pneumatic one like Tt use on the tai chi do?
Thermaltakes systems as with CM sometimes are not up to scratch, but you know, you wont know until you try. ;)
Hope this wont class as a competetor (who in their right mind would pay their prices for PC parts anyway) but RS compoments stock the gas springs with an adjustable lift, they normally come with the mounting hardware, i did have a few around but can only find a big one that will be too powerful for that. linky Have found a 240mm x 6mm dia rod one but not much pressure left in it, very weak.
Nice project BTW
You should have the power button in the nose, so you can flip it up to reveal a red button.
or
The nose could twist 90 degrees to turn it on.
Well if you need any large pistons you could just go to a scrap yard and take some off old cars, maybe just use them for show on some of the larger pieces. Smaller ones are tricky unless you buy them.
I recon car ones would be far too big and heavy tbh. I'll keep an eye out for smaller ones, but ive got plenty to get on with at the moment.
OT; Hello Darlo person :)
