- 4 Dec 2021
- Doncaster
Hi everyone.
This is my first ever build log so please bear with me, but it is by no means my first PC build. The project name comes from my 2 youngest daughters, Ariyah and Orijin.
As background, due to some temporary financial issues I was forced to sell my beloved PC a few months ago and now that's mostly sorted I am starting to build a new one.
This is going to take some time, updates to this log will most likely be weekly (I'm paid weekly so will be buying parts on a weekly basis) and that's also mostly deliberate... I was forever changing my last build because I was always in a rush and would just settle for whatever I could find in stock at the time, instead of just waiting and buying what I actually wanted / needed. This time around I am still limited by a budget, but I am willing to take my time to get everything exactly right the first time.
This is going to be a pure gaming PC with a nice aesthetic and fully watercooled. The following specs are planned for this build:
Case - Thermaltake The Tower 900 (white)
Mobo - MSI X570s MPG CARBON MAX WIFI
CPU - Ryzen 5 5600x or 7 5800x, I'm undecided if the extra cores are worth the heat.
GPU - This is the most difficult part and will most likely be the last part I buy (unless some generous hardware rep decides to sponsor me with one ), I'm aiming for at least an RTX 3070 / RX 6800 but if GPU prices don't sort themselves out I might end up with a GT430 at this rate lol!
RAM - Corsair Vengeance RT white 3600mhz 32GB.
Storage - WD Black PCIe4 1TB for OS, probably WD Blue PCIe3 1TB(s) for games, but will just see what the best deals are when I'm ready to buy as performance doesn't really matter for game storage. I don't want a mechanical drive, or Sata, I'm aiming for minimal noise and cable clutter.
PSU - 850W Seasonic Focus GX.
Cooling - 2x 560mm Alphacool XT45 or UT60 with Artic P14 fans
XSPC D5 with Barrow top
Random no brand tube res I have in my spares box
CPU block will likely be the Alphacool Nexxos or Watercool Heatkiller
GPU block will be whatever I can find for whatever GPU I can get.
Fittings will be all Barrow or Bykski hard-line as I've had good experience with them and they're cheap(ish) compared to other brands.
Hardline tubes, likely 14mm, and clear premix coolant.
Mods / my vision:
Everyone I've seen with this case does the "mini screen in the hard drive bays and dual loop / dual res" thing... I'm going to do this differently. My pump and res will be in the back, only the tubing and blocks will be viewable.
I'm planning to put a sheet of Plexiglass going from the top of the front bottom air inlets (where the 5.25 bay is) angled up to just below the upper cable management holes. This will (hopefully) be large enough to incorporate an old 17" monitor I have laying around, along with the project name back lit with aRGB strips either side... This is hard to explain, but will make sense once I have the case next week, confirm my assumed measurements, and actually get it done. If there's room for a fan, I will be adding one to help with general motherboard cooling. If the spare screen I have won't fit, I'll look for something smaller that will. The only water cooling tubes visible in the front will be one either side of this plate, going up to the GPU, across to the CPU, and back down symmetrically with pass through fittings.
All cables will be custom sleeved by me, in a mostly white with pink and dark blue to make it pop. The CPU EPS cable will definitely be made from scratch as stock cable has no chance of reaching while being cleanly routed, but I might be able to get away with just sleeving the stock cables for everything else, I'll know for sure once the case arrives.
Updates to follow, and I'm really looking forward to getting this project started.
I'm going to be concentrating on doing the case mods and wiring first, then the cooling system in the back, before finally the actual working components. As such, the above component spec may change depending on how long everything takes and any new releases.
The PSU came today, the case is due next week, and I'm just waiting on the sleeving coming from China to get on with the cables.
Mods / my vision:
