- 4 Dec 2021
- Doncaster
On the plus side, at least the sensor panel is working well.
It's a bit disconcerting to see the cpu essentially idling at 60c, doing nothing but downloading cyberpunk and running aida64, is that normal for these CPUs? I did run the aida64 stability test and the temp creeped up to around 87c which is below the thermal throttle limit but I will be happier once it's under water.
It's the first time I've ran a cpu on a stock air cooler in... A longer time than I can even remember, so not really sure what to expect to be fair.
Had a quick play around with aquasuite and realised I really don't have a dam clue what I'm doing... I can't even figure out how to change fan speeds, I've found a way to drag points on a graph but the actual fans don't seem to respond. Luckily the Octo only controls the radiator fans so I've got time to figure it all out before I actually need it to work.
