- 4 Dec 2021
- Doncaster
Got bored and started to disassemble the second monitor for the Snowblind mod.
Now I have a bit of a problem... the ribbon cable connecting the power and control board to the LCD is comically short, as such this will be a bit of an issue in regards to where I can place the board. The board is horrendously ugly so I definitely don't want it in view, but have so far come up empty handed in my search for a longer cable.
The ribbon cable I took out of the first monitor appears to be the same and is long enough to move the control board to just beyond the bottom edge of the screen, but for reasons I can't figure out the screen only displays green lines using that cable (it's fine with short one).
Current thoughts are to mount the board to the side glass, covered from view with vinyl on the outside and spray its metal housing black to cover it on the inside of the case... certainly not an elegant solution, but could work.
As our house returns to normality after the madness of Christmas I can fetch the case and everything back downstairs this week so I can play around with placements and see what I can work out. My new 480mm rad will be here on Wednesday anyway so will be getting them installed this week either way, along with splicing extending and sleeving the fan wires so there will be 2 fans per channel on the Octo and a little less cable clutter.
