IT'S ALIVE!!!!
Well some progress! My bending rubber arrived. and it slipped into the tube like..... well you know
My Phobya fan controler and F-F connector arrived too...
so LETS DO THIS
First bend went in ok and yes it does add weight support to the contraption below it *phew*
and the first link in the "Long run" from CPU to 240 Radiator
It was after this that each pipe either needed two bends or I got paranoid I was running out of PETG (I had 1 500mm pipe left at the end) and started reheating pipes I had
****ed. The result? Not the clean lines I wanted. Instead I seem to have some piece of "modern art". I knew my first lines would be bad but damn.... ah well £35 of PETG ordered tonight. Thats 20 tube\10 meters of pipe..... im sure ill get it right eventually
Basicly one of my main issue war orientation when the pipe had 2 bends in different directions and planning length. So will do mroe study on how to plan better. Also gonna chat to a jack of all trades mate of mine and ask for some tips
SOMEHOW however, Each pipe passed my rigorous testing process to see if it was compromised (i put my thumb at one end and blew in the other
) So with that QHSE genius in place ONWARD!
So Right, lets plan to evacuate the loop pronto and get the drain hooked up.
Catheter in place
So lets add some fluids...
*SPLASH* WHAT THE
**** JUST HAPPENED? JEBUS
**** I'VE FLOODED THE BOTTOM OF THE CASE!!!!
Thank god for all that kitchen roll, it absorbed it all and let none to components.... Ok i expected a wee leak, but not a flood...... (no pic taken cos.... well yeah im sure you understand.... Ok so lets take a quick look around..... huh the bottom of the Reservoir is still dripping...
Well..... that will do it.... Ok plug that back up and fill.....
Im only using 2 fans at the moment. 2 rikety old 3 pin fans i nicked from an old case. they are being used as mount points for the top radiator. and i still cant hear it. Hopefully the Venturi fans will prove just as silent
Leak test has now been running for over 2 hours and im getting impatient.... Time to give life to this beast!!!!
