solemn looking great!
your dremel skills are...interesting...
a tip for you re: the red cathodes (LED strip from 3M is fairly diffuse btw)
If you have a model shop nearby, they should have a supply of transparent heat-shrink film used to cover the balsa models, usually sold by the meter so probs looking at £5-6.
I used to have a thread on another forum, can't find it now, where I wrapped the length of the cathode tube in two or so layers and taped it together, it made the cathode actually emit red light!
Or maybe buy a white cathode and wrap it
So I have ordered some Crimson vinyl that would go on car headlights hopefully it will help with it.Haha yes my skills with the Dremel are lacking! But with the Trim it isn't sooo bad, but still not spot on either![]()
you case reminds me of certain scenes from Dexter!
Practice makes perfect, so they say.
I think you have been very courageous with this build.
Awww, I really like it, think it came out quite a bit better than I thought it would actaullyIt was all going so well until you decided on the blood spatter...![]()
It makes me think of Kill Bill.![]()
Looks very good i wana see it finished! Them dremel skills tho :/ Cant say im much better mind you
The trim helps with it esp if you are looking at it from a Great Distance
aww I feel bad, we're all being really mean about the dremel-ing
props to you for having the balls (ovaries!) to cut up your case and paint it, its looking good keep going
Good to see you have put it to good use![]()
Love the splatter mod
been following your build and loving it.
Yeah some say its not perfect but I haven't got the balls yet to build a new rig.
Now I've got my new build I'm gonna take my old pc apart and rebuild it a couple of times to see how difficult it is and have some fun.
Maybe I'll get brave enough tp DIY it when I upgrade some parts in the next year.
Want to move a couple of fans and maybe add a watercooling and go x2 or x3 sli.
Just seen this in the 'flesh' looks really good! a lot of nice work in such a small case!
gratz!
and almost no one notices the bad dremel work
