I know, the pun is rubbish, and the only real link between blood and the build is red dye, but that's all you're going to get this time of day
Anyway, the plan is to essentially install watercooling into a Lian Li V1000Z. I'll be cooling the CPU and GPU, but as I change the GPU fairly regularly (maybe too regularly...) I've gone for a core-only block.
I'm no newbie to watercooling, but I've headed in a different direction with this build compared to previous attempts in that I've gone for a high-fpi radiator, coupled with some nice high speed fans. It's also a little experimental, in that I'm trying to run it on only a single GTS240, with good temperatures, so we'll see how it goes.
Anyway, current system (which will be carried over) as follows:
CPU: i7 920 D0
Motherboard: Rampage III Formula
RAM: Patriot Sector 7 1600MHz CAS8
GPU: Asus GTX480
Sound Card: Asus Xonar Xense
Power Supply: Seasonic X-Series 650
SSD: Kingston V-Series 128GB
HDD: Western Digital Caviar Black 500GB
Current system (bit of a clue on the colour scheme):
New case (already mounted the Lian Li tool less PCI-slot holder - it's not fully compatible with the V1000Z though, as I can only screw it in at the top, so I'll have to sort that out at some stage):
As you can see, I've already mounted the XSPC reservoir (very eager...
), and my trusty Lamptron Touch fan controller - which I can wholly recommend - 30W per channel (used to have an 18W DDC running off this)
And the watercooling kit:
CPU: EK Supreme LTX Nickel/Plexi
GPU: EK VGA Supreme HF
Pump: Alphacool VPP655 (D5 minus top)
Reservoir: XSPC Dual D5 bay
Radiator: Black Ice GTS240
Fans: Scythe Ultra Kaze 3000rpm
Shrouds: Phobya 120x120x20mm
Fluid: Deionised water + Mayhems deep red dye + Pulse Modding Kill Coil
Tube: XSPC 3/8" / 5/8"
Fittings: 3/8" Perfect Seal barbs
Here's a line-up:
EK Supreme LTX:
EK's usual lovely packaging revealed an even lovelier block. I've gone for the nickel/plexi to show off the dye, and the finish is superb:
EK VGA Supreme HF:
Pretty much ditto the LTX sentiments:
Alphacool VPP655:
Just a D5 minus the top which many will replace anyway. Absolute bargain at £58.
Radiator/fan/shroud combo:
I have to say that I agree whole-heartedly with those who say that Black Ice radiators' finish is impeccable, they really are superb. Mix that 240 with a decent fan and a shroud, and I hope to have a winning combination. I'll be experimenting with and without the shroud to see what kind of differences (if any) are observed:
30 fpi goodness
I hope this introductory post has been ok, and I'll leave it here with one last pic, a clue perhaps, as to where I'll be focusing first...
...Anyway, the plan is to essentially install watercooling into a Lian Li V1000Z. I'll be cooling the CPU and GPU, but as I change the GPU fairly regularly (maybe too regularly...) I've gone for a core-only block.
CPU: i7 920 D0
GPU: Asus GTX480
), and my trusty Lamptron Touch fan controller - which I can wholly recommend - 30W per channel (used to have an 18W DDC running off this)And the watercooling kit:
Here's a line-up:
EK Supreme LTX:
EK VGA Supreme HF:
Alphacool VPP655:
30 fpi goodness
. Will be following this one all the way. Any plans to powder-coat the inside?
