Project: Bleedin' Li
Marv, if you post some pics and a small log of how you spray-coated the case internals that would be awesome :). I've never painted anything before (usually outsource) but quite fancy doing some spray-painting of some old cases.
I think I can manage that - it looks like we're about to get a thunderstorm here, so I'll paint tomorrow (just finished doing all the cable holes and whatnot with the case apart).
B&Q are doing 3 for 2 on all paint this weekend, so I got 3 cans of Plastikote for £13.96 this afternoon, which should easily be enough for most Lian Li cases' internals.
Right, so here's the start of the next update. My apologies for the picture quality, I haven't got access to the D90.
It was getting quite overcast outside, and I can hear thunder in the distance, so I decided to bring the washing in, and wait until tomorrow to spray the case. However, it did allow me to prepare the case parts, now that they're all covered in finger prints and metal shavings.
I've basically used the same technique I used to use when I sprayed RC car bodyshells, as it works well.
So, here are the parts after removal, and the various cutting/dremelling etc. The dust and finger prints are easy to see.
Always listen to something decent in the background ;)
Note Lian Li's helpful QC sticker remnants
First, wash the parts in hot soapy water. I don't find that using a cloth works any better than hands at this stage, so I just use my hands to wipe the surfaces.
I know my watch is black, but I'm not a goth...
Secondly, rinse the parts with cold water to remove any soap suds, as they will dry with a nice film that prevents the paint from sticking.
Then dry the parts with a rough tea towel, this 'roughens' the aluminium very slightly, and helps the paint to stick. After that, you are left with some lovely clean, finger-print and grease free parts ready for spraying. Obviously avoid handling the bits except on the edges right now - basically like handling a motherboard.
Lovely Lian Li aluminium goodness
Hopefully the body-shell spraying technique will work quite well overall, if not, call this 'guide' a log of how not to do it... :D
damn you in going to have to spray mine if yours comes out as well as im expecting :)
Hehe, well, let's hope so. Just going down to the basement to spray it now...
There won't be any 'in progress pics' as the basement is quite dark and photos will look crap. So I'll take some finished pics and post the method.
looks great :D although you might want to clean your sink, it looks kinda grubby :l
:unless it is meant to be that colour, in which case ignore me :D
Looking forward to the results of the painting session.
Looking forward to the outcome too. :)
Hope it goes well.
Well, all the bits are done, so pictures tomorrow hopefully! Quite a few paint runs though, flat surfaces are harder than I thought...
Thanks! The sink is quite old now, but the black marks and such are simply wear, and the middle sink thing has always been off colour. They have a speckled colour really... :D
no problem, keep the pics coming!
Ok, so after spraying over the BH weekend, I've reassembled the case, using screws and nuts rather than rivets. There are a fair number of paint runs, so the next time I spray a case, I have the following tips:
  • Practice a little with whatever spray paint you've bought to find out what the 'dust' and 'heavy' pressures are like. Basically, how much do you have to press the nozzle to get a dust of paint, and how much to get a river... I (stupidly) didn't do this, as I'd had much experience of Tamiya spray paints before, but hadn't appreciated the fine line between the dust setting and the heavy setting
  • For the first few layers, use the dust setting. Coverage won't look perfect, but you won't get runs!
  • Only when you've got a fairly even coverage can you start with heavier layers, but even then make sure you methodically work and don't cover the same area twice per coat. Sweep past quickly, and start and finish off the ends of the work - this prevents heavy patches.
So, the results (forgive the picture quality, I have no idea where the tripod is, so my hands were a little shaky):
If you're wondering what the grille in the middle is for, it's there to provide airflow from the radiator to the rest of the components, rather than just relying on the exhaust fan to draw air out.
The wire going across the motherboard tray is an NZXT red LED kit. At first I was going to hide the PCI controller, but then I thought that it actually fitted fairly well, and I don't need that slot, so it's staying.
Amazingly, this is the only picture where the paint runs are really visible
So, next up is the braiding!
Looking good mate, once all together I'm sure the paint runs will be forgotten about, I got all mine back together but did think I should do the inside black but now it's together there's very little silver showing anyway
Looks very promising, Will wait to see more updates from yourself, Really wish i had some money myself to build a lovely PC like this
Okay, the build is now complete, I'm writing this on the PC. Sorry I had no actual build pics, but it didn't go quite as smoothly as planned.
All I can say is that the results of a thin 240 radiator vs an i7 and GTX480 are surprising...
Update soon...
EDIT: Teaser:
