- 9 Jul 2008
- Bristol
Hi
Just going to be working on a new Gaming Rig. And try and make it look as clean as possible
The whole case will have a white/blue theme to it.
This is my first proper project and it might work and it might end up looking VILE!
Spec
Case: Lian LI PC-A71B (Will be powder coated white (inside/outside)
Side Pannel: W-75BT
Top Pannel: T-713B
CPU: Core I7 920 DO Stepping
Motherboard: Gigabyte GA-EX58-UD5
Ram: Patriot Viper 6GB
Graphics Card: ATI 5870
Sound Card: ASUS Xonar D2X
Power Supply: Enermax Revolution 1K
Hard Drive: Intel 160GB 25x-m SSD
Cooling: CPU: Heatkiller 3.0 LT White
All Fans in case will be Enermax Clusters
Case and Side Pannel has arrived
I Will need order the Top Pannel, DVD rewriter and Fan Controller before I send it off to the Powder Coater
Spec
Side Pannel: W-75BT
Top Pannel: T-713B
