Project: Clean
*EDIT* V2
Ok my Xonar D2X has arrived :) with a Custom Paint Job :).
and Just got my Intel SSD 160GB G2 :)
Very nice.
Now I am waiting for a Mr Tom in wales to pain the 3.5 to 2.5 HDD converter white :).
Got another package today :)
5 Enermax Clusters second hand of the MM.
Need 3 more anybody got any for sell? :p
They are VERY nice fans yummy :)
The white light should go well inside my case :) there is a switch on the fans to turn the LED off :) nice touch!
Now is the question, do i leave the white braid on? or do i use the blue and white braid?
hmpf what do you lot think I should do?
Bit of a toughy that.
how visible will they be?
if wiring will lay close together you could do alternate then plait them together maybe
Just a thought.
well seeing as this is shaping up to be a pretty darn nice build (i do alike a touch of white), ill let you off with beating me to buying those clusters :P
Hehe cheers :D. As soon as I saw the thread for seeling clusters I HAD TO HAVE THEM :D.
Anyway tiny update.
Managed to do a little bit of braiding on the Fan controller before I ran out of heatshrink :(
Here is the fan controller out for the first time since Tom sent me the case :p
By the way this is the Nesteq FanMax 8-Channel Fan Controller obviously coated white.
First thing I did, I took the cables off.
Then had to get the pins out of the connector (was very easy)
Got one channel of the Fan controller done. but ran out of Heatshrink, will order more.
So what do you guys think about the Fans? Should I braid them or not?
Ok Finally bought something new :) and bought some more heatshrink will get some cables covered tomorrow :) I guess i should really buy a backplate for it for the waterblock and how do I flush it out properley?
