- 29 Dec 2014
- The "North"
Did you do model all your parts from scratch? If not, may I ask where you sourced them from?
I wish I could model them from scratch
So today I finished off two tubes, they took around 2-3 hrs each but I couldn't be happier. The first one was pretty easy with the use of the extender that was included with the EK pump.
However the second bend was a pain in the **** as no matter how hard I tried I couldn't get the damn thing to fit and look good. It's hard to show but there is not a direct bend route from the CPU to the GPU aided by the issue that the Monsoon insert isn't a perfect fit into the Primochill tubing due to the manufacturing tolerances. This meant I had to employ a second pair of hands into the task and now it looks good (after numerous attempts)
Now I'm tired and too lazy to make a tea or coffee so tomorrow after I have had some refreshment I shall continue.![]()
For the first bend I used my right angled mandrel from the monsoon kit. For the second it was a combination of the right angle mandrel and guestimation.Did you use any tools to bend them or did you do them by hand? looks neat, Can't wait to see this completed.
the one thing i don't like about Rigid tubing builds, the tubing alone takes a ton of time which i don't have![]()
Yes, it is worth the effort but I think this will be a hybrid loop where I use soft tubing for the tubing you cant see such as the radiator to pump connection as I can't find a way to get the tubing to bend in such a tight spaceI know your pain, I've only bent two pipes for mine and its not easy at all. First one for me was easy but the second one took 3 hrs. My third pipe was an all day affair and I gave up in frustration.
It just looks so good though its worth the effort.
That cpu to gpu bend looks spot on, I don't think you could have made it look any better.
Yes, it is worth the effort but I think this will be a hybrid loop where I use soft tubing for the tubing you cant see such as the radiator to pump connection as I can't find a way to get the tubing to bend in such a tight space![]()
Yep, it certainly is a better idea as I just cant see a feasible way of bending the tubing to get it to fit without using a ton of fittings. It is just simpler to get the soft tubing for the locations were you can't see it.I've always wondered how the heck people do those really tight spaces, But yeah best using Soft tubing for parts you don't see, JayzTwoCents did that in skunkworks, He used a bunch of Soft tubing in lower compartment which you couldn't see and just left the top part purely rigid
Is the lower tube coming out the fitting at a angle from the gpu? Gpu to cpu looks good.
Why didn't you sand the monsoon insert to fit or buy the correct insert from ocuk?
Is it done yet???![]()
Just produced some quick models of how the PC's interior may look using some models from Google and drawing tube runs. The pipes in the actual build will be clear but I could not find a way to draw clear pipes in Sketchup. I'm pretty pleased with the tube runs and hope I can get them as clean as this when I build it. There are some more renders but this is the best one![]()
Thank you, I'll have a look at it when I get backSend it this way and I'll finish the tubesLoving that motherboard and ram though!
Oh not sure if you have ordered the primochill insert, but mine was a blue alphacool measuring 9.2mm and 1 meter long. Fits my tubes perfectly and getting some clean bends from it.
Enjoy the rest of your holiday!
Man nice work in SketchUp!
this looks very similar to the build i want to do with regards to the case and watercooling setup, ill be keeping an eye on this, nice work so far, cant wait to see the finished product
