Project: Cubit 3
I knew you did :P you can mount a sfx psu but obviously no room for gfx card. If they ever brought out v. powerful and short single slot cards or miniature closed loop water cooling for gfx cards, then i'd get a be quiet or silverstone sfx psu :)
Yeh, the back of the gfx card is a problem actually... still thinking of the best way to accomodate it properly! Have a semi-solution already but still thinking about a better one.. will see :)
thanks for the good suggestion :) My own idea is very similar to yours. I want to maximise cooling so will have to either do that very sparingly or attach these rubber 'thingies' to the back of the gfx card and let it 'rest'. If it's not too tight in there, i may be able to suspend it in a better way... will have to see. My rubber thingy solution gives it around 3-4mm clearance between the back of the card and the tray so i think that should be ok? :)
actually, you could remove 4 screws as close to the corners as possible, then change them for some standoffs with the right thread
also what is the total internal length of the case?
again, i might not even need to do that... my modding life has been made much much easier by one of the items pictured above :)
Total internal case length is around 200mm. Short :P
what helps you with that?
I want a tiny, powerful build :( although I do love my skelly, a m-itx build would be a secondary gaming/htpc rig
also I think you should definitely get the gainward phantom 560ti, that thing is awesome :D do you have enough room to fit a dual slot card in the hard drive bay part?
A picture speaks a thousand words, so i'll show you what i mean.. hopefully by this Wednesday :)
Sadly, no room on the left... that was the stock area for a single slot gfx card... has about 26mm clearance. My initial idea was to find an aftermarket cooler slim enough to fit in there.. i did manage to find one but the cooling pipes at the top meant i couldn't fit it in! It was pretty frustrating actually :P
As for the phantom (lovely card btw :))... i can probably just about fit that but it would require more modding.. not sure if it's worth the effort. I'm currently eyeing up the Gainward Golden Sample GTX560 ti. The dimensions ticks all the boxes :) so will probably go for that instead.
edit: just saw yours, very nice work there btw :)
sorry, keep misunderstanding you! :P
Yes, i can easily fit a dual slot gfx card in the stock HDD area :) (thanks to Gainward/Palit redesigning the stock pcb to the gtx 560!)
Im starting to hate all these small builds I feel it would look better if I had a Asus Maximus Gene-IV on a Lian-Li test bench "/. You could use a Pico PSU
why the hate dude? :P
Pico psu not an option. Currently there are no manufacturerers making anything above 200w. Plus it's rather expensive for what it is. Using a standard atx psu bolted to the underside of my desk is (for me) the best solution for my intended build :)
edit: yeh, no phantom :( If i don't got for the ODD then i can easily fit one but I need it (hate the idea of needing to buy an externally powered usb one... too much clutter)
you could face the cooler on the phantom towards the metal of the bay, then cut out a bit so the phantom's cooler will fit
That's an intersting idea :) ..and one that could work now that my cpu cooler is only 46mm in height now meaning there's a bit of room to play with.
Assuming there's enough room (which i doubt), the new positioning of the card now means i need a longer pci2 riser cable. I've looked and 15cm is about the longest i can find. I could buy another and add it on but that's more cable clutter to deal with. Also, securing the pcie riser will become a lot more involved as currently it's very straightforward.
The tray mod would involve more work too and if i wanted to upgrade with another gfx card, i'd probably have to fab another tray... not very appealing. i think the GS version will have to do :P
Because I was all set on the one in my sig and the only Test Bench I like wont fit my mb I don't think, its a shame about the Pico PSU too. Won't it worry you about the legnth for the PSU?
All I will say from my experience is: Heatpipes ;)
I'd have the GPU fan pointing downwards, modify the front faceplate to fit a 120mm fan a la Silverstone Sugo for some cool air, and use a heatpipe based cooler for the CPU so you can leave plenty of air inside for the GPU.
IIRC the i5 is a 95W TDP chip, so something with a decent amount of surface area would be best (I was working with 35 W TDP and used laptop heatpipes, and a modified Shuttle cooler at one point)
As for the GPU, I mounted mine using rubber grommets from a Lian Li and it went some way to isolating the vibration from the fan which sounds bloody awful as it's an all aluminium case. Make sure you fit the case feet too, that makes a HELL of a lot of difference to sound!
