Project Cyclone
This is looking good, very intrigued to see where it goes.
thanks :D
Small update for today
until more stuff arrives next Tue/Wed
Holes cut in the aluminium plate for the bulkheads
drilling and filing the hole out of the acrylic
Bulkhead fitted with 45 degree Monsoon fitting to test and measure for cuts
Rough layout of how the bottom of the case will be shaped, you can see where the tubing will pass through etc
a lot more to do, but its starting to take more shape now
Right bigger update
warning, lots of pics :P
My wrap arrived!
5m x 1.5m of the stuff, wasn't cheap :(
Started to set up the radiators and whats going in the rad box
Measuring out the vinyl wrap for cutting
Box done!!!
Separation plate for the case done
How she looks stripped out
Bare naked Sabertooth
New and improved white Sabertooth!
How she looks inside the case
Close up of the ram
Thank you Enermax!
With 1 x GPU in
Close up of the custom braided cables
Bit more populated
Computer desk looking worse for wear :(
So many scratches
Measuring out more wrap
Looking better
Looking much better!
Testing out the LCD, and gathering ideas where to place this
Switched on, so i could update the thread :P
Lots more to do, just wanted to get the base of the build done!
Will start on the water cooling tomorrow!
small update
Mid plate installed
Res installed to where its going (ignore the fact its hanging, itll be sitting on a shelf
PSU cover in to check, and dremelling some acrylic out
Close up of one of the 7950's (don't worry, cleaned the dust off lol)
GPU block back plate
1 x gpu water block ( have 2 of everything lol )
I love the look
MSI twin frozr 3 BE without cooler
Fully naked
Fresh thermal pads on for VRM's etc
More to come eventually
I quite like the loop of the floating res, it's be cool if you can find a way to mount it so it appears to be floating still, rather than sit it on a shelf.
Thanks guys!
just ordered some more custom cables ( 4 x 6pin ) as to neaten the look up
Just reviewing a water cooler for Play3r.net then i shall be able to continue!
