Project Eclipse (watercooled 900D + Haswell)
Bloody fantastic looking build!! Definitely subbing up to this.
One question, your cable management on the back, how did you get all the cable to stick to the case? Did you have to buy additional brackets?
I put some sticky back cable holder in.
Are you running those 2 switches at the bottom from right hand side of your display panel to the molex for your lighting
Yep. Unfortunately the Mayhems UV red I was sold is not UV :(
photo by GodAtum, on Flickr
I am ocing now and will report back with results :D
Nice work man looks good but no real need for toture testing all you need to do to make sure that your pc is stable is to use it as you normally would.
Great looking build, I can't believe I've not seen this before. I'm also interested to find out how your attempt to run 4.8ghz went. Keep us posted buddy :)
