- 6 May 2015
Introduction
Hello and welcome to project Erebus. My previous project, Aether, was a Crossfire R9 290X, watercooled Corsair 450D build. Erebus will be bigger and faster. The plan with this project is to create a silent, powerful gaming machine based on the X99 platform. 4K graphics and fully-watercooled, with rigid tubing.
Main components
Watercooling components
Peripherals
Confirmed sponsors
I would like to thank my kind sponsors for making this project possible.
Hardware acquired so far
Updates
Main components
- Case: Corsair Obsidian 900D
- Motherboard: MSI X99S SLI Plus
- CPU: Intel Haswell-E i7-5820K
- GPU: 3x XFX AMD R9 290X
- Memory: Corsair 16 GB DDR4 Vengeance LPX 2666
- Display: iiyama 4K FreeSync and 144 Hz FreeSync monitors
- PSU: Corsair AX1200i
- Cabling: Custom-sleeved with E22 Teleios
- Radiators: 2x Alphacool NexXxoS UT60 Full Copper 480mm
- Pumps: 2x Alphacool VPP655 (Laing D5)
- CPU block: Alphacool NexXxoS XP³ Light (Black Chrome edition)
- GPU blocks: Alphacool NexXxoS GPX
- Reservoir: Alphacool Cape Corp Coolplex Pro 25 LT
- Fittings: Alphacool HT 16mm HardTube compression fitting G1/4
- Tubing: Alphacool HardTube 16/12mm plexi clear
- Coolant: Custom Mayhems purple pastel
- Fans: 16x Corsair SP120 Quiet Edition
- Fans: 3x Corsair AF140 Quiet Edition
- Fan controller: Lamptron CM615
- Flow sensor: Aquacomputer High Flow USB
Peripherals
- Keyboard: Corsair Vengeance K70 RGB UK
- Mouse: Corsair Vengeance M65 RGB
Confirmed sponsors
Updates
