Project: Erebus
Pretty straightforward if you have a Dremel. You'll need some fairly thick stick pads to attach the bits, as they are hollow underneath. Also, you might lose some paint on the cut edge revealing the metal beneath - I used a black marker to cover it.
Thanks mate. I'm very happy with the coolant from Mayhems. See below for finished pics...
thanks, ill give it a go.
nice job on the rest of the build , its not often you see people managing to pull of a black and purple scheme.
love it!, Looks ace in purple :), very nice job on those interior panels aswell, Im thinking to do the same with mine. Where did you get those little circular carbon stickers for the fans? I'd like some of them to put on mine.
Only thing i dislike about the 900D is the smoked window :(, got a acrylic panel coming next week which is clear which i will drill and fit it as i hate the blue hue around the window from my white lights, cost £12 cut to size and polished around the edges at 6mm thick so looking forward to that :D.
love it!, Looks ace in purple :), very nice job on those panels aswell. Where did you get those little circular carbon stickers for the fans? I'd like some of them to put on mine.
I bought some carbon fibre vinyl from Amazon and cut it to size.
Yes, the blue glow! I tried to position LEDs pointing away from the window as best I could to avoid it. With hindsight an acrylic panel would've looked ace. Where did you order it?
There are many places that do cut to size acrylic, I ordered from here http://www.theplasticman.co.uk/index.php?area=calculator. They were the cheapest but take a 3-4 days to get the stuff cut and polished which I dont mind waiting.
Measured as 500mm x 422mm.
It will sit about 1mm back from the door though, corsair stepped their panel down around the edges so it sits level with the door frame.
I will drill it myself using the old one as a template. Then will have a nice clear shiny panel :D.
Just wish corsair did a clear panel for it would be much easier.
Can't stop drooling over this build, so awesome... Defo using this as inspiration for my next build
Thanks for that. I'd love to see your results...
I'm a FAN of this build.. Real nice job :D
FANtastic! Thanks ;)
Thanks mate, I look forward to seeing it.
