- 26 Aug 2015
- York
So, I've been building computers in one form or another for about 20 years or so now and I've been saying that the next build will be watercooled for the last 3 builds...
So I finally took the plunge and bought myself the parts for a Skylake build and I even have most of the parts now. Just waiting for the cpu (should arrive today or tomorrow), fittings, sata cables, coolant and an ssd sled.
Components:
Watercooling loop:
Day One
Up to press I have only been able to do the test fits for the pump/res combo and the rads just to make sure everything fits.
I did discover however that I will have to remove the top section of the frame in order to install the 280mm rad... good job its attached with screws in the Evolv then...
The first test, I had to drill mounting holes as none of the pre-drilled holes fit the photon.
First test, wider view
The second test, this time I added in the rads and one of the top fans to make sure I had the correct clearances. The top rad will be rotated in the final config.
Second test, wider view
Components:
- Case: Phanteks Enthoo Evolv ATX
- Mobo: Asus ROG Maximus VIII Hero
- CPU: Intel i7 6700k
- RAM: 32Gb G Skill Ripjaws V @ 2800Mhz
- GPU: 2x Gigabyte GTX 980 Windforce 3 with ROG Sli bridge
- PSU: Corsair RM850 with Cablemod individually sleeved cable kit
- SSD: 2x Samsung 850 Evo 250Gb in RAID 0
- Storage: 2x Samsung Spinpoint 2TB 2.5"
Watercooling loop:
- Rads: Alphacool NexXxos ST30 280mm & 360mm
- CPU Block: EK Supremacy Evo Nickel/Plexi
- GPU Block: 2x EK FC980 GTX WF3 & Backplate
- Pump/Res: XSPC D5 Photon 270
- Fittings: Monsoon free centre hardline black
- Tubing: Monsoon acrylic 16mm tubing
- Fans: 2x Noctua NF-P14s redux & 3x Noctua NF-S12b redux
Day One
