Today I've been filing down the edges of the areas where I've been cutting and also filling the holes at the bottom of the case to give a cleaner look.
Not much to show for a days work, but you've got to go through this patch to get to the enjoyable stuff.
Used wood filler rather than metal (as it was all I had. I've used wood filler before on cases and it's absolutely fine. I'm actually convinced from the smell that it's the same stuff anyway.
The Big hole is where the lock goes.
Case and internals all keyed and waiting to be washed prior to their primer coat.
But looks like this is coming along nicely
ofcourse it isn't a 120mm saw for a 120mm fan. The build is looking good though
Very nice,
