The case has arrived! It looks fantastic, and I particularly love the inlays on the side panel. The triple layered acrylic on the front looks awesome too, and creates a great effect on the fan grill. Parvum are working on a couple of tweaks to one or two of the panels but overall its great!
Cheers guys. Been testing some hardware placement and gotta say the motherboard looks like it was made for this case... Looks awesome. Will post some pics later.. Will also give you guys a better idea of the internal space too.
Back from hols and started working on the project again. A few time consuming jobs done this weekend.
Firstly, fan rings painted on my corsair fans to match the theme:
[/URL]
And then some more cable braiding! My Enermax PSU is only semi modular, so to help cable management I've reduced the ATX and 8 pin connectors down to a couple of inches and then custom made extensions for the correct length:
And test fitting some of the watercooling gear to start to get an idea of tubing. (the res isn't the res I'm using - new one on the way).
