Project Fortis [Parvum ATX Build!]
Thanks for the comments guys!
Just trying to figure how to get a very stuck stock cooler screw off my 2nd gpu. Just won't budge so can't get the water block on. Anyone got any tips?
A bit drastic, but had no choice in the end and had to drill it. Not something you ideally want to do on a £500 graphics card!
Can't wait to see the rest of the build man. I'm blocking up my GPU for the first time tomorrow and dreading the thought of screws stuck in the cooler!
Been a little while since my last update, but I have been making steady progress... here's and update:
I've painted the pump housing so its properly matt black and matches the black acrylic of the case. Looks very stealthy:
A similar job on my Essence STX. The plate had faded in the light and looked more golden than black, so that had to change:
I've cut holes in the midwall for tubing to pass through from one rad to the other. I figured this was going to be the easiest way to do the tubing as the ports nearest the midwall are quite hard to access especially using hardline. It also has the benefit of being able to watercool my fan controller:
My gigantic EK X3 res arrived - this things is huge, but I think its gonna look good!
And finally, I've started bending the tubing! This is a first attempt, and certainly one of the tubes I think I can improve on, but you get the idea of how its going to look below:
That's it for now! The backplates should arrive from ColdZero on Monday, which I'm looking forward too. Other than that I'm a bit stuck until I receive a couple of replacement panels from Parvum, then I can properly mount the pump and res. Frustratingly our useless Royal Mail lost them in the post so the guys at parvum are sending out some more!
Thanks mate... I'm pretty pleased with the tubing as its my first attempt. Does take a fair amount of time though compared to normal!
Looks awesome! I'm most interested in getting a Parvum ATX case - one based on the Magnus infact. Need to talk to the Parvum guys really.
Hey all! Update time! The backplates arrived and they look awesome. Thanks a lot to Ricardo at ColdZero - great job!
Here we go:
Sadly still no replacement panels. Getting a bit frustrating now as I cant really progress any further without them and this build has already taken way longer than I had hoped! Oh well... hopefully more updates soon.
Those GPUs look stunning with those backplates and SLI bridge. I also love the backplate for the sound card. Much better than looking at a PCB. Also I did not know you could watercool fan controllers (I assume it requires a custom waterblock?)
As always sublime work :)
Thanks for the comments guys. I definitely recommend coldzero based on these backplates.
very neat build mate. what sort of coolant you are planning to use.
The coolant will be mayhems pastel yellow. It's all hear ready and waiting!
Thanks mate. The fan controller is a aqua-computer aquaero 5. It's fully programmable based on sensor readouts. However it can get quite hot on the stock heat sink which reduces max power output so aqua computer do a little water block for it. I'll post some pics later so you can see what I mean!
Time for another update! The panels arrived, so I can really get on and finish the build now :)
Here's todays work:
The new floor (now solid, without the radiator grill) was one of the panels to arrive which meant I could get on with the pump and res mounts:
The res will have extension fittings with plugs on the bottom, which go through the two large holes. This means the res can sit flush on the floor, while the fittings help locate it in position and also act as rather useful drain ports at the lowest point of the whole loop!
And the underside of the floor - you can see the two drain ports:
Pump mounted into the floor:
I also cut the holes for the fill port in the roof - looks nice & flush countersunk into the top roof panel - this goes straight into the top of the res:
And I've mounted the fan controller and HDD:
That's it for now!
