project: Fractal design get's bigger
After a half-year-break Christmas brought some new hardware.
The Athlon II X2 had to go for a Phenom II X6 1055T and the Radeon HD 4870 gave way to a HD 6950 which got flashed to an HD 6970.
Of course I have some pictures for you:
The HD 6970 has so much power that I can't really use the power with one display. So I just took 2 more and build up an eyefinity setup. And it's really impressive to play on 3 monitors with a resolution of 5760x1080 (6.2m) pixels.
This is real fun:D
I hope I'll have more time to complete the projekt in the next months.
Timee
OP do you feel your hard work has been made redundant with the launch of the Fractal XL?
Or do you think its different enough to stand on its own?
Thanks.
Thank you,
I think it's different enough and it's selfmade and I'm just planing another modification to get a second radiator in the case.
It isn't sure whether it becomes real because the cost are very high, and the modification is really complex due to the fact that I have to puzzle something on the case.
But I can show you the alpha plan:
file.php
file.php
At least I have to say that just two of these Monitors are mine. The third one I picked from my brother while he was by my grandparents:D
Timee
