Project: Gattaca
I decent temp drop there.
You have been the inspiration to start my take on a similar project in the next couple of weeks.
Unless your using exactly the same hardware as me its a bit of lottery, but there are some really good guides/blogs on the net.
I'd suggest removing the reference's to os x on pc hardware especially the links and mods will get unleashing their whips soon as its against the license agreement
There is a part in the EULA about not being allowed to run OSX on non stamped Apple hardware but I think I have that covered.
And just in case you were wondering its a bought retail copy of OSX Snow Leopard 10.6.0.
awesome build man, im hoping mod a G5 case for a pc.
was wondering what moddle of G5 was the case from? and do you know if the cases change in the different generations of G5?
may be a little of a cheeky question but how much did you pay for the G5 case from the bay?
mint condition ones seem to be over £150
thanks.
thanks.
Thanks! :)
It was a dual G5 2Ghz system originally, I picked it for £66 + delivery from the bay which was pretty cheap.
Thanks! :)
thats very good :)
thinking of bidding on one, it has a couple of scratches but i am thinking of doing a design to the ''apple core duo'' mod so will be sanding all of the outer cage to smooth aluminum.
what do you think i should be willing to pay for a slightly damaged case?
was thinking of about £50~ +p&p
Time to add a splash of water :)
I have a few water cooling parts hanging around which I will be re-using for the refresh.
I am also upgrading the 9500GT 512mb with an 8800GTX 768mb graphics card.
Water cooling parts list:
EK Supreme
EK X-Res 140 + DDC Ultra 18w
EK 8800GTX Acetal
Only problem is I don't have a rad for this one, any recommendations?
yoo. sweet couldnt say ive ever seen anyone use an apple case. did everythink fit in nicely then? or did you need to do some mods too it..
