Project: Gattaca
Time for that stock cooler to go, NH-D15 installed with a bit of a squeeze, temps now idling at 28c.
Oh.. and as its 2019 some RGB Fans :)
https://i.~ibb.co~/hDS5pQ9/20190908-154915.jpg
The NH-D15 clears the side panel by about 3mm which means it could be possible to use some thermal pads and sink the heat pipes directly to the side panel, not sure if that would actualy make a difference but may be worth looking into in a future update.
