but then, you might get to muchArthalen said:Note to all modders here: Get ALL your materials before you start work to prevent supply problems.
ChoÞÞer said:but then, you might get to much![]()
if he is going water cooled, no needEliot said:are you going to improve the airflow? all you need is a thick drill bit
Jakal91 said:LED's well be white, with matching cold cathodes lighting up the HL2 window in the side of the case. I am also changing the HD activity light to white.
Pete_m said:white led's are the new blue![]()
Blue will never be replaced my friend, blue + black = winrar.Mark A said:Blue will never be replaced my friend, blue + black = winrar.
Hmm i think red led's would look pretty good with that case.
Mark
Yewen said:Blue + Silver.
Red + Black.
How I operate, best combinations to my taste, but I only normally like LED's and maybe at a push a cathode!
