Project Hardon
  • Thread starter Thread starter 233
  • Start date Start date
233
233
21 Nov 2004
Wishaw
my daughter has been nagging me for a new rig for a while now
current rig is a very early amd quad of pc world origin (was a cheap and cheerful £300 system 6 years ago and its really starting to show its age :(
so I was given some requirements
able to play sims 3
be cool
be small
so far i'm still at the acquiring all the necessary parts stage
heres what I have so far
EVGA Hadron Air case
Gigabyte Z87N Wifi mobo
Pentium K
8gig of Teamgroup 1600mhz ram
Thermalright AXP cooler
I have a 4870 that will get her up and running but still on the to acquire/steal/borrow list
a decent GPU
SSD and storage drive
some led lighting
lists getting shorter woot
seriously tempted to pull the spare 2tb out my own rig and borrow my 280x to get this up and running for now, i'm desperate to have a crack at overclocking the K and see what it can do
once I start building (which is going to be a challenge the Hardon is tiny. so I don't think it will be anything too fancy but should hopefully be a nice neat build.
in case your wondering the project name came from my wife who questioned why I had been googling erections on her laptop :)
I'd like to put in a recommendation for a Rajintek Adios cooler - it's one of the biggest air coolers you'll get in the air, it's good, quiet, and costs £15.
Also - CABLE TIES. You will need millions. I used a near entire pack of 100 for my hadron build and while I'm proud of the cable management and it's pretty good, it could still be better.
I came here expecting pics of his hardon, I leave disappoint. :(
Was expecting to be like this tbh:
ooooh getting there, another couple of bits and bobs ordered
8 gig of ram and a Thermalright AXP 100 with a gentle typhoon fan
go well with the black silent that are already in the case :)
might actually start the build today as i'm sure a ssd and gpu can easily be fitted post build
in fact I've got a spare 4870 all I need is a storage drive, sure I can scavenge one from somewhere
OP, seriously needs to amend the post... hilarious as it reads, it's just wrong lol
might even post some pics up of me slipping the hardon out the brown box later
ooeer
Came in here expecting picture of Hardon, leaving disaapointed.
*edit meant project pictures not the other form of hardon...
build started
its TINY
easy part done
back plate fitted
cpu fitted
stock HSF on just for now
4pin connector next to the cpu slot err my psu doesn't have one is that necessary?
then it all went to pot
what a nasty horrible case this is, the cables are all far too short there is ZERO room for cable management and its just far too tight to work in.
this is going to be a challenge ;)
