Project Hardon
  • Thread starter Thread starter 233
  • Start date Start date
Cheers RJC
we has success
fully installed now and sitting on the desktop woot
all i have to do now is swap the 2TB mechanical out for a SSD when i get one and swap GPUs around once i pick one up for this add some lights and give the wiring a tidy
temporary lash up is lashed up
few problems though,
think the mobo is goosed. won't boot with a stick of ram in slot 1 :( tried 3 different sets of ddr3 in it so were down to 4 gigs until i get a new mobo or a 8x1gig stick
and the gnu is a lowly 4870.
hopefully have the thermal right arrive tomorrow and i'll get that fired on then give it a healthy OC
not a chance of getting the lightning in i think exterior dimensions of the case is 296mm wide :)
Pretty sure it's slightly over 300mm long, and you can add some length by cutting away a small part of the frame that the panel attaches to (the limit isn't the case interior, it's getting it in to begin with).
now sporting a over clocked 280x at 1200/1600 along side the K @4ghz :)
think it should be potent enough for 1080p gaming :)
thermal take arrived so i thought i better get the bleeding thing fitted :)
so stripped it all down again
cooler under assembly
looking good
oh ****
that isn't going to fit now is it
so start again
tighter than a nuns chuff
got the mobo bolted in then realised i hadnt plugged anything in oops
trying to fit the audio connector and system fan was a bleeding nightmare
lots of sweaty words
ahahahaha i still hadn't plugged the 4 pin in either what a noob
many many sweaty words later we have 4 pin audio and system fans connected
some added cable ties for a slightly neater build
and the finished build
clocked to 4.2ghz with a over clocked 280x at 1175, i think this will handle sims3/4 :)
future plans
might see if i can get a blue 100mm fan to mount on the cooler (any suggestions)
and some braided extensions for the 24 pin and 8 and 6 on the gpu just to neaten things up a tad
but happy with it for now
Looks great, should beast Sims 3 and possibly 4 (most likely a memory hog).
And agreed, that fan is pretty ugly, the blades are like an off yellow colour?
Great little compact build, I can totally see the benefit of a small rig like this. My case takes up SO much room on my desk, I'd consider re-housing it all into a smaller case if I didn't love the Haf X quite so much :)
going to pull it apart again today :) got some nice new blue fan extension cables arrived today, really should leave it till my 6/8 and 24 pin extensions are bought but hey why not
